In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequency?
June 6, 2022 at 9:58 am
FAQParticipantNo. For a single mode, the ratio to critical is greater at frequencies below resonance and smaller at frequencies above resonance. This is documented in the Structural Analysis Guide Section 1.2.4. You can find the complete equation in the ANSYS Help documentation, under “Mechanical APDL -> Theory Reference -> 14.3.3 equation 14-22 parameter g, mj, gEj”.
The damping contribution g is related to the damping matrix by
[C]=(2*g/Omega)*K
Omega is the excitation frequency. So (2*g/Omega) is a coefficient times the stiffness matrix like Beta damping.
Beta = 2*eta/omega
omega is the natural frequency while
2*g/Omega = 2*eta/omega:
eta (ratio to critical) = g(omega/Omega)
In a single degree of freedom test you will see the ratio to critical be higher at low excitation frequencies and lower at high excitation frequencies.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
