August 25, 2023 at 12:16 pm
SolutionParticipantFor overcoming the convergence difficulties: 1. Try reducing the angle/ distance between two parts before going for impact analysis – this helps in reducing the applied load 2. Reduce the FKN (Normal Stiffness Factor) value in the contact settings 3. Try running your model with impact constraints. Using Impact Constraints help a lot with these as to not add artificial energy to rebounding impactor. 4. Increase the no. of sub steps Please refer to the model attached.
1. 2048660.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
