How do you define a general anisotropic creep behavior that is a direct function of a full stress tensor (not just SEQV)?
June 6, 2022 at 9:58 am
FAQParticipantAll of our standard creep material model options are isotropic and functions of SEQV. Isotropic creep can be combined with TB,HILL, to simulate anisotropic behavior, but this is still derived from SEQV. To define a more general anisotropic creep behavior derived directly from a full stress tensor and to output a full 3×3 creep tensor, one would have to program a USERMAT.F routine and create state variables (SVAR) for the stress, strain input and creep output. (USERCREEP.F cannot be programmed for anisotropic creep since it is still dependent on SEQV.)
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
