April 13, 2023 at 7:33 am
SolutionParticipantQuestion: I know how to generate the total displacement plots for all modes, but how do I EASILY generate nodal stress plots for all modes? Also how can I likewise generate directional deformation plots for all modes? Answer: There is no direct way to achieve this using UI options in Workbench Modal Analysis for the stress plots. Attached please find an example. To change any of the command parameters, user can refer to the APDL command help. Following is an alternate method using UI instead of APDL script command object for Directional Deformation result: – Go to the ‘graph’ window and select all modes >> RMB click and say “Create Mode Shape Results”. – This will create Total Deformation – Select all the total deformation (ctrl +Shift) – In the details of total deformation >> Type >> Direction Deformation
1. 2060963.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
