For Harmonic Unbalance Mass rotordynamic analysis in Workbench Mechanical, where does rotational velocity come from?
March 17, 2023 at 9:00 am
FAQ
ParticipantThe unbalanced force = m*e*omega^2. where m is the unbalance mass, e is the eccentricity (distance from point to center or ‘rotating radius), Omega is the shaft spin speed which is the same as the excitation frequency defined in Analysis Settings after converting it from Hz to rad/sec
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to include effect of bolt pretension in a modal analysis?
- Presentation on shock analysis using response spectrum and transient dynamics
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
