For Harmonic analysis, how to input large text files for frequency dependent real and imaginary pressure data?
May 15, 2023 at 8:32 am
SolutionParticipantComplex pressures must be applied with a surface effect element (surf154). In Mechanical you can use APDL commands to create surf154 elements on a face and input the real and imaginary pressure tables. If the pressure is frequency dependent and also varying along a direction then the pressure table rows should be corresponding to frequency and columns should be corresponding to directional position(X/Y/Z) if any. The first row and first column in the text files should be used for indexing therefore should not have pressure data. In the data file, first column should have corresponding frequency values and first row should have directional position values. The first row and first column used as index numbers are stored in zero row and zero column in APDL table. The index values should be in ascending order. Following is an example where text files for real and imaginary pressure values are imported into Mechancial using command snippet. The pressure is frequency dependent and also varies along the X direction. The input text files preal.txt, pimag.txt and Xlength.txt are copied to Mechanical project’s solver directory.
1. 2056222.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
