September 26, 2022 at 9:53 am
FAQ
ParticipantIssue
While using ANSYS Discovery products an ANSYS Licensing Error is displayed and licensing of the products is being denied.
Causes
ANSYS Discovery products need to reach a cloud based license server and the connection requests could be blocked by customer firewall settings.
The following components can be affected when a firewall blocks requests to the licensing server:
- ANSYS Discovery Essentials
- ANSYS Discovery Standard
- ANSYS Discovery Ultimate
- ANSYS Discovery Ultimate Geometry Interface Bundle
- ANSYS Discovery Ultimate Geometry Interface Bundle for CATIA
- ANSYS Discovery Essential STL Prep for 3D printing
- ANSYS Discovery KeyShot HD
- ANSYS Discovery KeyShot Pro
- ANSYS Discovery Algoryx Momentum
If your network is protected by a firewall, the following exception rules need to be implemented.
Firewall Exception Rules
- Enable https communication over port 443 (in-going and outgoing) to the server located at https://ansys-fno.flexnetoperations.com/
- Exclude the ansysls_client.exe (subscription handler) process on your company firewall
ANSYS Discovery products licensing requests might also be denied by your antivirus software or by missing user permissions in Windows. If you are still experiencing issues after adding the aforementioned firewall exception rules, please try the following troubleshooting recommendations.
Troubleshooting
- Add ansysls_client.exe (subscription handler) to the list of allowed apps of your antivirus software.
- Make sure you have user permissions to write to the following folders on Windows:
- %LOCALAPPDATA%
- %Temp%
- Ansys Discovery Hardware Requirements (2025 R1)
- What’s New in Ansys Discovery 2025 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- ANSYS Discovery: Compatibility Utility
- Discovery: Black screen with no geometry appears after launching Discovery
