Do you have a simple example of SMART fatigue crack growth in which a tabular R ratio (stress ratio) and tabular pressure loading are considered?
Tagged: 2020 R1, fracture, materials, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantYes, please check the attached Workbench Project Archive. Block A contains the simple geometry. Block B contains a simple crack analysis with fracture parameter calculation. Block C contains a simple SMART Fatigue Crack Growth (SMART FCG) analysis. Block D contains a SMART FCG analysis with tabular R ratio (R=K_min/K_max). Block E contains a SMART FCG analysis with tabular R ratio and tabular pressure loading. Further information about Paris’ law and how SMART calculates crack growth depending on loading, stress ratio R, etc. you can find in the ANSYS Help at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_frac/franundcgrowmech.html and https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_frac/fracSMART.html section “3.2.1.6 Specifying the Crack-Extension Increments in a Step”. Please note: The sole and only purpose of the given example model is to illustrate the workflow of SMART FCG features. Accordingly, please use the provided data (especially material data) with care and make sure to use own engineering judgement if the applied assumptions are physically adequate.
1. 2062192.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
