Do the directions of the orthotropic thermal properties change with the orientation of 3D elements, or are they always parallel to the global Cartesian coordinate system?
August 25, 2023 at 12:16 pm
FAQParticipantMaterial properties are defined in the element coordinate system, as such it doesn’t depend upon global Cartesian coordinate system. In Mechanical, users can change the element coordinate system. 1. Create new coordinate systems with orientation as required. 2. In the details View of the part, specify the new coordinate system for the part, it will be the part’s element coordinate system. Please refer the attached image which shows, how to change element coordinate system for the part.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
