September 26, 2022 at 9:59 amWatch & LearnParticipant
With Discovery Live you can spend more time with questions and answers and less time with traditional simulation processing steps. It provides real-time data on temperature distribution as you make 3-D model changes, or change input characteristics like heat flow and material type. Most importantly, Discovery Live let’s you test your ideas in real-time so you can achieve your design goals in a fraction of the time than you otherwise could have done.
- Discovery Live: How to change units
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM – Scaling deformation contour results
- Project Text to 3D Geometry in SpaceClaim
- Creating a Helical Geometry in SpaceClaim
- FAQ: Discovery SpaceClaim and Discovery Live offline help document
