Tagged: Application Example, Discover AIM, How To, polymer, polymer-extrusion, tutorials
September 26, 2022 at 9:59 amSolutionParticipant
How-to for the simulation of the extrusion of a rubber coating onto a solid cable. The outer diameter of the coating is prescribed as a free surface and the final coating shape is exported as a .stl file. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM – Scaling deformation contour results
- Project Text to 3D Geometry in SpaceClaim
- FAQ: Discovery SpaceClaim and Discovery Live offline help document
- Discovery AIM – Butterfly Valve With Reed Flow Sensor Fluid-Structure Interaction How-To
