Legacy Products
Legacy Products
Discovery AIM: Application Examples: Fluids
    • FAQFAQ
      Participant
      In addition to learning the power of Discovery AIM in these tutorials, the following application examples will expand your knowledge and discovery to new levels.
      Download and open these files with saved solutions in Discovery AIM and review the setup and solution to gain an understanding of what ANSYS can help you Discover.
      1) Fluid Flow Simulation of a Shell Tube Heat Exchanger
      Application example of a shell tube heat exchanger simulation. This is a fluid flow only simulation where the flow of water and air through the heat exchanger is calculated. Thermal effects are not calculated. This project requires release 19.0 or newer.
      Download the file here
       width=
      2) Fluid Simulation of a Porous Medium in an Exhaust System
      Application example of an exhaust system including orthotropic porous media and thermal fluid conditions. This project requires release 19.2 or newer.
      3) Non-Newtonian Fluid Flow Simulation of a Blood Vessel
      Application example of a fluid flow simulation of non-newtonian blood through a blood vessel. This project requires release 19.0 or newer.
       width=
      4) Fluid Flow Thermal Simulation of a Thermal Mixer
      Application example of a fluid flow thermal simulation of a thermal mixer. This project requires release 19.0 or newer.
      5) Fluid Flow Simulation of Natural Convection
      Application example of natural convection of air between two concentric cylinders where the inner cylinder is hot and the out cylinder is cold. This project requires release 19.1 or newer.
       width=
