Tagged: AIM App Example, discovery-aim, electromagnetics
September 26, 2022 at 10:00 am
SolutionParticipantIn addition to learning the power of Discovery AIM in these tutorials, the following application examples will expand your knowledge and discovery to new levels.
Download and open these files with saved solutions in Discovery AIM and review the setup and solution to gain an understanding of what ANSYS can help you Discover.
1) Electromagnetic Simulation of a Reluctance Motor
Application example of an electromagnetic simulation of a reluctance motor. The current through the coils is specified and the magnetic flux density, and torque on the rotor are calculated. This project requires release 19.0 or newer.
2) Electromagnetic Simulation of a Magnetostatic Actuator
Application example of an electromagnetic simulation of a magnetostatic actuator. The force acting on the contact is calculated based on the current through the coil. This project requires release 19.0 or newer.
3) Electromagnetic Simulation of a Hall Effect Sensor
Application example of an electromagnetic simulation of a Hall effect position sensor. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
