How can I apply an acceleration time history to the big mass when using the Big Mass Method in a mode-superposition transient?
March 17, 2023 at 9:00 am
FAQ
ParticipantOrdinarily the mass is excited by a force equal to the acceleration times the big mass, but a more convenient way is to apply the acceleration directly with the CMACEL command which can be used to apply an acceleration to an element component consisting of just the big mass.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
