What is the Quality Factor in FEModeler mesh metrics? Are the Quality Factor in FEModeler and the Workbench Shape Metric in Simulation the same?
Tagged: 11, FE Modeler, General, modeling-and-meshing, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantThe quality factor is computed for each element of a model (excluding line and point elements). This metric is based on the ratio of the volume to the edge length for a given element. A value of 1 indicates a perfect cube or square while a value of 0 indicates that the element has a zero or negative volume. This mesh metric is not used by Simulation in the meshing process.
