Legacy Products
Legacy Products
Discovery AIM – Fluid Flow Thermal Simulation of a Shell Tube Heat Exchanger With Baffles
    • SolutionSolution
      Participant
      Shell Tube Heat Exchanger-Fluid Flow-19.0.wbpz.zip
      Application example of a shell tube heat exchanger with baffles simulation. This is a fluid flow and thermal simulation where hot water in the shell is cooled by cold water moving through the tubes. The temperature distribution through the steel structure is also calculated. This project requires release 19.0 or newer.
