May 17, 2024 at 2:02 pm
Chen Yi
Subscriberwhen I simulation D-ring on workbench student 2023R2,I apply hydraulic pressure on both sides of the D-ring,then solve successfully,but the information include errors."Element 867 (type = 2, PLANE182) (and maybe other elements) has become highly distorted.  Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere.  Try incrementing the load more slowly (increase the number of substeps or decrease the time step size).  You may need to improve your mesh to obtain elements with better aspect ratios.  Also consider the behavior of materials, contact pairs, and/or constraint equations.  Please rule out other root causes of this failure before attempting rezoning or nonlinear adaptive solutions.  If this message appears in the first iteration of first substep, be sure to perform element shape checking. *** LOAD STEP   2  SUBSTEP   10  NOT COMPLETED.  CUM ITER =   94*** BEGIN BISECTION NUMBER  1   NEW TIME INCREMENT=  0.35000E-02".who can help me? Some parameters setting as below. Thank you.
May 20, 2024 at 5:45 am
Chen Yi
Subscriberwho can help me ?Thank you
- The topic ‘Workbench2023R2 simulat D-ring solve successfully but information include errors’ is closed to new replies.
