January 20, 2023 at 11:15 am
February 21, 2023 at 8:02 amSRPAnsys Employee
The solid-phase stresses are derived by making an analogy between the random particle motion arising from particle-particle collisions and the thermal motion of molecules in a gas, taking into account the inelasticity of the granular phase which are given by 14.177.
All of the k-e turbulence models are available, and may apply to all phases or to the mixture. All other features available in ANSYS FLUENT can be used in conjunction with the Eulerian multiphase model, except for the following limitations: The Reynolds Stress turbulence model is not available on a per phase basis.
Thanks
- The topic ‘Will solid-phase Reynolds stress tensor be included when using granular model’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
543
523
225
209
