May 20, 2021 at 4:18 pmPuhanSubscriber
Hello
I hope everyone is doing fine.
I want to ask why my values coming 1/1000 less than the original values from Ansys solved examples.
The problem is 'Delamination Analysis of a Double Cantilever Beam Using Contact-Based Debonding'. For detail you can visit
May 20, 2021 at 6:49 pmPuhanSubscriberSorry sir to bother you again I know you did not use this feature but I think the problem seems only in units, not in any contact bonding problem. I am a little desperate to find the solution as I have a deadline. Kindly help. I will be grateful.
With regards
Biswabhnau Puhan
May 21, 2021 at 6:11 amMay 21, 2021 at 11:43 amPuhanSubscriberDear Erik
Thank you very very much for the constant help.
I did exactly according to your advice I tried that same too again. Changing that in the model only changing the units in the interface. I have already double-checked and it is giving the same error as previous. It is not converging and the values are 1000 times higher than actual.
With regards
Biswabhanu Puhan
May 21, 2021 at 1:08 pmPuhanSubscriberFor example, to show the properties I put is exactly the same
My simulation
Ansys Solved
These are CZM and composite material respectively. I really don't understand where is the difference. I even changed the Ansys solved model according to mine to show
My simulation
Ansys Solved
If you see the workflow it is exactly the same, so it's kind of a mystery. Even if I change everything exactly as mine Ansys giving correct result than me. Kindly help please.
With regards
Biswabhanu Puhan
May 21, 2021 at 1:17 pmErik KostsonAnsys EmployeeI do not know actually - perhaps someone else has some tips.
Erik
May 21, 2021 at 1:32 pmPuhanSubscriberOkay, thank you very much. I hope someone helps, it is a little strange.
With regards
Biswabhanu Puhan
August 11, 2021 at 7:21 pmPuhanSubscriber
Dear
Sorry, can you please share the link where this type of delamination problem has been solved by Ansys step by step. Here as far as I remember you shared a link, but unfortunately I can not find it now, please share the link again where it is explained step by step the delamination problems and the Ansys file. Sorry, I am in a hurry, that's why tagging you directly.
Sorry its not this page :https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb_vm/wbvt_VMSIM089.html
There is a different page where it has been carefully explained each step in ANSYS, I need that page, kindly help.
Regards
Bhanu
Viewing 7 reply threads- The topic ‘Why the value I am getting 1/1000 less than the original from Ansys solved example?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
- Script Error Code:800a000d
Top Contributors-
1301
591
569
524
366
