February 1, 2022 at 2:59 pm
vendeville_lj
SubscriberI'm trying to get a SCCM application for ANSYS 2021 R1 up and running, but the installation keeps failing with error 0x80091007(-2146889721). If I run the script from the same network location the SCCM application is pointed to, the program installs properly and without incident. Some of the things I've tried:
Redistributing the application; no change to the error.
Re-validating the application; no change.
Re-creating the application; works on the first couple of test machines, but fails on subsequent installation attempts.
The script I've been using is:
\networklocationANSYSANSYS2021R1setup.exe -silent -licserverinfo 2325:1055:licenseserver
echo Set oWS = WScript.CreateObject("WScript.Shell") > CreateShortcut.vbs
echo sLinkFile = "C:UsersPublicDesktopANSYS Workbench 2021 R1.lnk" >> CreateShortcut.vbs
echo Set oLink = oWS.CreateShortcut(sLinkFile) >> CreateShortcut.vbs
echo oLink.TargetPath = "C:Program FilesANSYS Incv211FrameworkinWin64 unwb2.exe" >> CreateShortcut.vbs
echo oLink.Save >> CreateShortcut.vbs
cscript CreateShortcut.vbs
del CreateShortcut.vbs
ping -n 20 127.0.0.1 > null
February 8, 2022 at 9:35 pmGeorge Karnos
Ansys EmployeeViewing 1 reply thread- The topic ‘Why does my SCCM application keep returning error 0x80091007(-2146889721)?’ is closed to new replies.
6395
