Ansys Products
Ansys Products
Why can’t I start Fluent launcher 21r1?
    • l_koers
      Dear all,
      A few weeks ago, I somehow became unable to start the fluent launcher I had pinned to the windows taskbar. It started to give me the following error:
      The launcher is C:\Program Files\ANSYS Inc\v212\fluent\ntbin\win64\fluent.exe If you're missing dll's then it may be something else has overwritten some of the common files. This seems to be becoming a more common issue as other software providers overwrite common files rather than including their own.
    • l_koers
      Hi Rob Thank you for your reply.
      It helps that the cause of the problem might be more clear, but I'm not sure how to proceed.
      I forgot to mention that CFX launcher worked fine and it seems to be a Fluent-related problem. I've uninstalled everything and installed Fluent and SpaceClaim only, but the problem persists.
      If I take a look at the target destination of the Fluent shortcut, the target is ""C:\Program Files\ANSYS Inc\v211\fluent\ntbin\win64\fluent.exe" -r21.1.0 -shortcut". If I remove "-shortcut" or " -r21.1.0 -shortcut" from that target destination, it launches fluent in local parallel mode.
      Does that launch the launcher so you can set parallel options etc or launch the solver directly?
    • l_koers
      It launches Fluent in meshing mode. If I switch to solutions mode its in 3d, double precision, local parallel mode.
      So no Fluent launcher to adjust any settings
      What happens if you click on "Solution" in the top left? It sounds like you used Fluent Meshing and need to open the solver.
    • l_koers
      Hi Rob I got the following suggestion from the firm that sells and consults in Ansys in the Netherlands.
      It took them a few weeks, but it probably had something to do with a permission issue for a folder. I was asked to run the code below in the windows command prompt:
      ______________________________________________
      setlocal
      pushd .
      cd /d"%appdata%"
      ifexist Launcher(
      move Launcher Launcher%time::=%
      cd /d"%localappdata%"
      ifexist Launcher(
      popd
      mkdir c:\zansys1
      set homedrive=c:
      set homepath=\zansys1
      endlocal
      I'm don't understand the specifics but I've got access to the Fluent launcher again.
      That looks like it's removing the %appdata% folder - it's a common fix when the software does something weird. Roughly the %appdata% holds the user settings and can get messed up, so removing it means the software recreates the folder without the rubbish.
    • l_koers
      Thanks for clarifying Rob!
Viewing 8 reply threads
  • The topic ‘Why can’t I start Fluent launcher 21r1?’ is closed to new replies.
