Ansys Products
Ansys Products
Where can I find how many processes and GPGPUs my ANSYS,Fluent has?
    • Mark Twain
      I forgot where to find..
      Where can I find how many processes and GPGPUs my ansys, Fluent has?
      If input wrong number will program notify me and can this be reason for program to not respond?
      Ansys 2022 R1
      On start up or during a pause in a run?
      On start up you set the process count, and you should then see an error if you try and use more than your licence permits. Note it is possible to launch 8 cores parallel on a 4 core machine, and it won't help performance. GPUs behave differently, and unless you're using the new GPU solver I'd leave those alone for now.
      During a pause in a run, check the options under the Parallel tab (top ribbon) and I think it's listed in the Load Balancing menu.
      • Mark Twain
        loading balacing menu show number  of cores that you set at launch.
        Can I find this in licence manager?
      Yes and no. The LM will show what's being used, but I'm not sure if it'll tell you how many you're using (ie itemised list) as opposed to total for everyone.
      • Mark Twain
        So how I find how many cores/processes my licence has?
      That's in the licence file.
      • Mark Twain
        This is file is at C:programs /ansys?
        I opened but cant find it HPC number.. ?
      The licence file is wherever you put it, or where IT put it on the system. You're looking for a line something like
      INCREMENT aa_a_hpc ansyslrnd
      Unless you're using Ansys Student, which is covered here https://www.ansys.com/academic/students/ansys-student
Viewing 4 reply threads
  • The topic ‘Where can I find how many processes and GPGPUs my ANSYS,Fluent has?’ is closed to new replies.
