October 7, 2024 at 11:03 pm
Aric Meyer
Ansys EmployeeWith the release on October 7, 2024 comes a new capability in HPS to specify a local scratch directory. By default, Mechanical APDL solves will use local scratch if available on the selected hardware. For other solvers the setting must be enabled. The steps are given below.- In the Ansys Access on Microsoft Azure web UI, HPS virtual desktop table row, click Connect  to launch the Ansys HPC Manager web app.
- Sign in to Ansys HPC Manager.
- In the navigation pane, select Resources.
- In the compute resource list, select the autoscaling cluster.
- Select the Properties tab.
- Here you can choose either of these methods:
- Once you have finished changing the settings, scroll to the top of the page and click Save.
Viewing 0 reply threads
- The topic ‘Use local scratch drive for faster solving over HPS’ is closed to new replies.
