January 9, 2025 at 3:54 amjijojose2024Subscriber
Hii all,
I have been working on DPM for a while, initially when i used surface or single solid cone injectors the results ( temperature at the monitoring point was stable.... like converged to a nearly single value... but now i am using multiple solid cone injectors, and the temperature at the monitoring point is very unstable like varying about 30 deg. Can anyone say why is that?
Note: this is the cooling of a exhaust pipe using water injection inside the exhaust. Both continious phase and DPM is stable, and not transient.
January 9, 2025 at 10:51 amRobForum Moderator
If you plot temperature contours to see how the temperature variation is behaving how does it look? Just because the input flow is steady it doesn't always mean the output is! Also check DPM concentration (read the definition) to make sure you're not overloading a region (ie if the spray cones overlap/interact).Â
January 27, 2025 at 4:15 pmjijojose2024Subscriber
my outlet temperature is varying randomly ... not even in some regular intervals
January 27, 2025 at 5:04 pmRobForum Moderator
What about velocity and planes along the flow path.Â
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- access to path files denied error
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Questions and recommendations: Septum Horn Antenna
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
1882
802
599
591
366
