February 19, 2023 at 12:10 amJoey ChanSubscriber
I have been using CFX for a while. Recently, I encountered a problem where I could not run any CFX simulation due to licensing problem. I contacted our IT support for help, but they replied that "I can see from the server logs that qf***@DESK******* has checked out a license and there are multiple free licenses". They have also restarted the license server, but it didn't solve the problem.
As far as I can tell, modelling, meshing and viewing the result (post-processing) work just fine. However, generating the definition (before starting a simulation) takes longer than usual. Of course, the simulation can’t start at all. Does anyone know how to solve this problem? Thanks!
Log from the solver:
 License Cap:  ANSYS CFD SolverÂANSYS LICENSE MANAGER ERRORÂCould not connect to license server: 75**@DESKTOP-*******. System error: 0 "". License ID:   License checkout failed (CFD SOLVER).ÂANSYS LICENSE MANAGER ERRORÂCould not connect to license server: 75**@DESKTOP-*******. System error: 0 "". +--------------------------------------------------------------------+ | ERROR #001100247 has occurred in subroutine .           | | Message:                              | |                                  | | The solver is unable to continue because of licensing problems.  | -
February 27, 2023 at 4:28 pmANSYS_MMadoreAnsys Employee
Can you please share the content of the logs showing the error in the %TEMP%\.ansys directory?
- The topic ‘Unable to use ANSYS CFD Solver due to license error’ is closed to new replies.
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
1406
599
591
550
366
