September 12, 2025 at 4:14 am
September 12, 2025 at 11:52 am
Federico
Ansys EmployeeHello,Â
can you show how you have set up your Dynamic Mesh zones?
September 12, 2025 at 12:18 pm
September 17, 2025 at 12:04 pm
Petros
Ansys EmployeeCan you try adding at least 3 elements in the thickness of the solid region? Also try and see how the default of Unified Remeshing works before switching to Methods-Based Remeshing.
September 19, 2025 at 4:07 am
Swapnil
SubscriberI tried with a refined mesh, but the issue still persists.Â
September 19, 2025 at 8:06 pm
Emmanuel-akor
SubscriberHi Swapnil, Your deformation values seems small so you shouldnt see high distortion. Your deformation result might be autoscaled. If you change the scale to 1 somewhere at the top menu, you should be fine. I've had this problem in the past with my FSI and thought I was doing something wrong.
September 22, 2025 at 9:54 am
Swapnil
SubscriberHi Emmanuel, thank you for your response. The error showing "high distortion in solid element" pops up in initial iterations itself. Therefore simulation is not complete.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
- Two-way FSI simulation
- Question about generating Porous Jumps
4562
1494
1386
1209
