September 18, 2025 at 12:49 pm
q.qin
SubscriberHi,Â
I am doing simulations for a cryogenic motor. I want to do a two-way coupling for Maxwell 3D and thermal 3D. Due to the computational complexity, I want to use the university's HPC to solve it. However, I have no idea how I should write the sub file and/or the Python file for these coupling simulations, and what files I should submit to HPC. I am wondering if anyone has samples?Â
September 19, 2025 at 1:08 pm
Ivonne Marti
Ansys EmployeeHi,
If the HPC cluster has a scheduler installed (e.g., RSM) and it's also installed on your machine, you can submit the job directly from the Electronics Desktop UI. To do this, go to the Simulation tab in the menu and:
- Select "Scheduler" – choose the scheduler you want to use.
- Select "Submit" – specify the model, HPC settings, and HPC machine name.
- Click "Submit Job"Â to run the simulation
More detailed information can be found in Maxwell Help > High Performance Computing > Submitting a Job.
If you want to submit the job using command line, please look in Maxwell Help > High Performance Computing > High Performance Computing (HPC) Integration > Command Line Information for Ansys EM Desktop Products
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4613
1530
1386
1209
