September 19, 2025 at 9:16 am
September 26, 2025 at 9:22 pm
Rabindra Paul
Ansys EmployeeHi Rathore,
Thanks for using the learning forum. It seems the model has PCB board and importing the trace. During the trace import process software needs to compute the metal fraction from the trace. The program is failing during that process. Is the model running for a single run - no parametric? If so, you can turn the option 'do not recompute metal fraction' in the trace import panel. If it does not run without parametric option then there could be something wrong with the trace file.
Hope this helps.
Thanks
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
1494
1386
1209
