January 19, 2026 at 2:27 pm
January 21, 2026 at 2:30 pm
Giorgos Papa
Forum ModeratorÂ
Hello Adam,
thank you for creating a post in Learning Forum.Â
Can you specify in more detail what is the question? Do you get unexpected results which do not match your observations from physically testing the components?Â
Did you only changed the loads in-between the analyses?ÂSome general suggestions would be:
1.Make sure you use the correct units in Mechanical and in Engineering Data. This is a frequent mistake that can occur and not notice.
2.What is your assumption? Do you have large deflection turned On for all analyses?
3.Check contacts and boundary conditions to detect possible mismatch between analyses.
Best Regards,
GiorgosÂ
February 11, 2026 at 8:44 pm
adam
SubscriberHello Giorgos,Â
I hope this message meets you well. Thanks for the comment. I´m sure that your suggestions will make my posts become better with more detailed information related to what we´ve been developing as a Student Team.
Actually, I'd like to add more information about this simulation, but I only was able to upload one photo and maybe it was the reason of some missing details. Is there any limit of images posted? How could I insert more visual details about?
I hope an answer back! Thank you!
Grateful,Â
Wagner
6379
