October 30, 2024 at 2:27 pmTim DukesSubscriber
Hi Support,Â
I am attempting to model a simple thermoelectric cooler in an enclosure.Â
This works OK when doing Thermal only simulation as in image below but when this is turned into a CHT to study air flow through the enclosure it doesn't seem to work. Is this a limitation currently?
Happy to share the model with you for you to take a look.
November 4, 2024 at 10:18 amDevendra BadgujarForum Moderator
Hi Tim,Â
Let me check with simple case at my end and will get back to you.Â
DevendraÂ
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
591
544
524
366
