June 10, 2023 at 1:56 pmNaresh JogiSubscriber
Hello,Â
I'm trying to find the thermal stresses on a structure. In my initial run, I see the thermal stress values are high, not sure why this is occurring. Also, I'm not sure if I set up the simulation correctly. Hot gas(860 F) pass through the internal structure as shown below, I even applied the convection on the outer surface of the structure(ambient Temp). I am not sure if I need to use heat flux or temperature to define this, I tried both ways and still the stress in static structural is close to 4.8xE^9. Please anyone can guide me on how to solve this simulation?Â
Thank you.
June 12, 2023 at 2:01 pmChandra SekaranAnsys Employee
Have you checked your temp coeff of expansion value and units?
- The topic ‘Thermal stresses’ is closed to new replies.
Ansys Innovation Space
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
599
591
565
366
