October 30, 2024 at 8:05 ama.montesSubscriber
I want know what is the correct model simulation for check the maximun temperature in a solid in a natural convection simulation? I made two simulation with two diferent method, a simulation without enclosure, with a convection factor calculated by iteration; and the other simulation, with enclosure (sometimes, appear the option to set the convection factor).
The simulation result´s are diferent betwen both simulation, and I don´t understand what is the reason.Â
I add some pictures to show each case. Best regards.
October 30, 2024 at 8:40 amDeepakAnsys Employee
It'll be better to ask in the Fluids channel.
October 30, 2024 at 10:29 amRobForum Moderator
But as a brief answer. If you assume a solid-fluid HTC you can model the solid only. If you include the enclosure (and mesh it well enough etc) the heat transfer between fluid and solid is a function of the flow and temperature: ie it's a more accurate model.Â
November 4, 2024 at 10:16 amDevendra BadgujarForum Moderator
Hello,Â
The First simulation is just solid thermal simulation and you can see the solid solid conduction/heat transfer.Â
Second simulation you did with enclosure you are modeling natural convection with fluid interacting with solid. This is Conjugate heat transfer analysis. You can refer these artciles for more information:
Thermal Analysis of Heat Sinks with Ansys Discovery | Ansys Knowledge
Parametric Analysis in Heat sink with two CPUs using Ansys Discovery | Ansys Knowledge
Let me know if you have further questions.Â
DevendraÂ
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
1301
591
544
524
366
