September 11, 2025 at 6:42 pm
September 11, 2025 at 7:59 pm
NickFL
SubscriberThe scales are different so I find it difficult to tell. The green in the lower image is about 100e3 and that corresponds to the orange in the upper image. Can you repost with the same scale? You can even change the scale to both have bands or be smooth. That will also help visually. As for your Warning message, check in fluent to see what these surfaces are. -
September 12, 2025 at 7:43 am
B D
Ansys EmployeeHello,
Please use consistant option for the Range option while creating the contour for better understanding. You can use "Local" option to get good idea of variation within the selected surface.
September 12, 2025 at 9:08 am
Forum ModeratorAnd linking in the other thread, Â https://innovationspace.ansys.com/forum/forums/topic/the-results-are-different/Â Â
Plot all models into one CFD Post case for comparison and also compare in Fluent.Â
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1494
1386
1209
