TAGGED: #meshingerror, 3d-wing, aerofoil, fluent-mesh, surface-meshing
September 17, 2025 at 11:27 am
karl.zammit
SubscriberHi all,
UPDATE: Why does meshing work when the geometry is saved as .stp and not when in native .dsco/.pmdb/.scdoc/.agdb ??
I’m struggling to create even a coarse surface mesh in Fluent Meshing for what should be a straightforward case: half a wing in axial flow inside a symmetric cuboidal (wide) domain. I’ve meshed more complex geometries before without issues, so this one has me stumped.
Geometry & setup:
* Created entirely in ANSYS Discovery (no imports).
* Wing trailing edge deliberately blunted to avoid zero-thickness.
* Airfoil/wing faces ensured to be single continuous surfaces (no fragmented profiles).
* Domain is a simple box; half-model with a symmetry plane.
* Using Fluent Meshing (Watertight workflow and manual steps both attempted).
What I’ve tried:
* Discovery Repair: reports no problems.
* Fluent Meshing Geometry Check: no errors or warnings.
* Tried very coarse global sizing, relaxed curvature/proximity, max cell size on all faces.
* Ensured no free edges, duplicates, or tiny sliver faces as far as the tools report.
The problem:
* The surface mesh generation fails every time, even with extremely coarse settings.
* I consistently get errors such as "Breakout detected" and "Front could not be closed" at the tip during surface meshing.
* No preceding geometry/health warnings to point at a root cause.
Question:
Is there a preferred export route from Discovery for Fluent Meshing?
Happy to provide the files for you to try it out and give out any additional details. I’ve been at this for a few weeks and find it odd given the simplicity of the setup. Any ideas or checks I might have missed would be greatly appreciated!
Thanks in advance.Â
September 17, 2025 at 1:47 pm
Anilkumar
Ansys EmployeeHi Karl,
Thanks for reaching out to Ansys Forum Support.
We would definitely recommend to use native formats as those will carry all the share topo, NS information which will be missing from neutral format like STEP. Could you please provide more details on the Dimensions? It appears to be issue with dimensions. Like the model size seems very large. Could you please try meshing the scaled down model of this? maybe 10 or 100 times scaled down model?
Secondly, try using standard unit system in the discovery instead of large unit system. Let me know on how this goes.
If it still fails then could you please share the transcript file details here? copy paste the details from geometry import to failure stage.
Thank you!
Anil
September 18, 2025 at 9:05 pm
karl.zammit
SubscriberHi Anilkumar,
Thanks for your message.
Surface meshing works for a 1:1000 model constructed using the Standard Length Scale Unit System, but fails when constructing a 1:10 or 1:100 model from scratch. Constructing the model in 1:1000 scale and then scaling up to 1:10 seems to work. However, the 1:1 scale desired requires the Large Length Scale Unit System.Â
Running the exact same Discovery Script in Large Unit System to create the geometry resulting in a 1:1000 scale model and then scaling up to 1:1 results in the following console error output pointing to errors at the tip:
Error: Breakout detected
Error: Failed to project bn7495 bn7475 (front-edges) onto face (120023.976563 -39964.031250 24737.519531) .
Error: Duplicate front Edge at (120057.707703 -39913.438446 26240.494405)
Error: Duplicate front Edge at (64037.059817 -11600.164437 42855.179537)
AÂ 1:1000 scale model constructed in the Large Length Scale Unit System produces similar errors, but somehow a surface mesh is generated. However, the 1:1 scale attempt results in:
"Error: The surface meshing was not successful."
I have tried both methods of construction: creating two solids (a wind and the box domain) and then intersecting, as well as using the 'Enclosure' method around the wing - both give a similar error output upon attempting the surface meshing task in Fluent Meshing. Again, I must mention that geometry checks in both Discovery and on import to Fluent Meshing produce no errors or warnings. The final file always only contains a single solid representing the fluid domain (not an incomplete surface).
September 19, 2025 at 6:48 am
Anilkumar
Thanks for the update and testings. Yes, this issue is due to large dimensions, so working on the scaled down model is recommended currently. This will be improved in our upcoming versions. Time being you can work on the scale down model and then later scale the mesh in solver to actual dimensions.
Anil
September 19, 2025 at 10:54 am
karl.zammit
SubscriberÂ
Thanks.
P.S. For anyone following the thread experiencing similar issues, the workaround that is currently working for me is opening up the 1:1000 scale model constructed in Discovery in SpaceClaim and scaling up to 1:1 there, as working with a 1000th-scale, scaled-down model is not an option for the scope of our current project. For completeness sake: performing the entire construction (!:1000 scale) then scaling up entirely in SpaceClaim also does not work (similar errors to those described above).
I have yet to attempt scaling up in the solver, as I was unaware that this is something that could be done.
I hope this helps.
September 24, 2025 at 7:11 am
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4592
1494
1386
1209
