temperature change fluid
    • bobd
      Dear,
      currently i'm trying to do a simulation of a fluent where the temperature is rising due to a polymerization reaction.
      For the temperature profile of the fluid I have written the UDF as follows;
      I have implemented this udf as the temperature of the inlet. But during my simulation the temperature of my fluid won't change. And after a couple of time steps I receive a floating point error.
      Is there someone who can help me?
      Kind regards,
      Bobd
      Turn off the UDF and see if the model runs without it.
    • bobd
      Yes, it works without the UDF
    • Karthik Remella
      Administrator
      Since you are using a mathematical expression as a boundary condtion, could you please see if you are able to use Fluent Expressions to resolve your issue? You might be able to entirely circumvent the UDF issue.
      Hope this helps.
      Best,
      Karthik
  • The topic ‘temperature change fluid’ is closed to new replies.
