July 18, 2022 at 6:42 pmzdfrankmanSubscriber
I have found that enabling the species transport wall surface reaction permits diffusion of species across the reaction wall. Is there any way to have both zero diffusive flux and a wall reaction?
July 26, 2022 at 2:45 pmRKAnsys Employee
Hello,Â
What is your end goal, why do you want to do this?Â
July 28, 2022 at 5:04 pmzdfrankmanSubscriber
I am simulating slow flow through a channel, where diffusion is dominant over convection. In this instance, O2 is reacting with a site surface catalyst to form N2. I would like to see a steady buildup of N2 and a steady loss of O2, but instead the N2 and O2 are rapidly diffusing through the reaction wall. I suspect this is because there is no specification of zero-flux through the wall.
August 3, 2022 at 9:14 pmzdfrankmanSubscriber
Is there any way to prevent diffusion through a reaction surface wall?
- The topic ‘Stop diffusion through a reaction surface wall’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
1191
513
488
225
209
