April 21, 2021 at 10:56 pm
callum.walley
SubscriberRecently installed 2021R1 on our cluster and CFX/Fluent have been failing due to a licence error.nUsing Centos7nUsers have no issues using 2021R1 CFX/Fluent on their local machines using the same licence server.nLicence settings are provided by setting ANSYSLMD_LICENSE_FILE = 1055@nAll previous installs of ANSYS work fine with identical setup.nComparing the licence debug logs of the same casefile run with v202 vs v211nv202n2021/04/20 10:18:44 NEW_CONNECTION nConnected to license server: 2325@ .n ANSYSLI_SERVERS: 2325@ n FLEXlm Servers: 1055@ n2021/04/20 10:18:45 CHECKOUT cfd_solve_level2 20.2 (2020.0507) 1/1/36/1375 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:18:45 CHECKOUT cfd_solve_level1 20.2 (2020.0507) 1/1/36/1375 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:18:45 CHECKOUT cfd_base 20.2 (2020.0507) 1/1/40/1375 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:18:45 CHECKOUT FEAT_CFD_BASE 20.2 (2020.0507) 1/1/40/-1 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n....n2021/04/20 10:19:07 CHECKIN cfd_solve_level1 20.2 (2020.0507) 1/0/35/1375 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:19:07 CHECKIN CFX_SOLVER 20.2 (2020.0507) 1/0/0/1 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:19:07 CHECKIN cfd_solve_level2 20.2 (2020.0507) 1/0/35/1375 77/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 n2021/04/20 10:19:07 CLIENT_EXIT 76/83/8640/8640 103417:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 56056:10.65.5.155 nv211n2021/04/19 11:08:15 INFO Starting Licensing Client Proxy server.n2021/04/19 11:08:15 INFO /opt/nesi/share/ANSYS/v211/licensingclient/linx64/ansyscl -acl 27126.33050 -nodaemon -log /home/cwal219/.ansys/ansyscl.wbl010.27126.33050.logn2021/04/19 11:08:15 INFO Started ANSYSLI server.n2021/04/19 11:08:32 CLIENT_CONNECT 1/1/1/1 27126:CFX_SOLVER:cwal219@wbl010.cm.cluster:linx64 9:10.65.5.163 n2021/04/19 11:08:32 NEW_CONNECTION Connected to Licensing Client Proxy server: 45742@127.0.0.1.n2021/04/19 11:08:33 INFO Parent Child context created with id 701e46cf-1bd3-47e6-9109-72d830ca38bd.n2021/04/19 11:08:37 CLIENT_CONNECT 2/2/2/2 27223:CFX_SOLVER:cwal219@wbl010.cm.cluster:linx64 10:10.65.5.163 n2021/04/19 11:08:37 NEW_CONNECTION Connected to Licensing Client Proxy server:45742@wbl010.cm.cluster.n2021/04/19 11:09:19 INFO Using Parent Child context 701e46cf-1bd3-47e6-9109-72d830ca38bd.n2021/04/19 11:09:19 INFO Unable to connect to FLEXlm path 1055@a ; adding to Unavailable FLEXlm Servers cache.n2021/04/19 11:09:19 DENIED FEAT_CFD_SOLVE_LEVEL2 21.1 (2020.1029) 1/0/0/0 2/2/2/2 27223:CFX_SOLVER:cwal219@wbl010.cm.cluster:linx64 10:10.65.5.163 n...nFailover feature 'CFD Solver - Level 2' is not available.nFLEXlm server is not responding. Resource temporarily not available.n ANSYSLI_SERVERS: 2325@ n FLEXlm Servers: 1055@ n2021/04/20 10:19:50 DENIED cfd_solve_level2 21.1 (2020.1029) 1/0/0/0 2/2/2/2 103425:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 10:10.65.5.155 n...n2021/04/20 10:19:51 CLIENT_EXIT 1/2/2/2 103425:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 10:10.65.5.155 n2021/04/20 10:19:52 CLIENT_EXIT 0/2/1/2 103232:CFX_SOLVER:cwal219@wbl002.cm.cluster:linx64 9:10.65.5.155 nAs you can see, in the v211 log it seems to be launching a proxy server on the local compute node and then failing.nnHow do I stop this from happening?nThanks in advance, some urgency.n -
April 26, 2021 at 8:13 pm
George Karnos
Ansys EmployeeArray
2021 R1 uses direct connection to Flexnet instead of using the ANSYS Licensing Interconnect like earlier version.
The proxy is needed.
On the license server, edit the license file and:
Edit VENDOR line to be: VENDOR ansyslmd PORT=1056
Make sure that port 1056 is added to any inbound/outbound firewall exceptions on all machines
You can run the following to test ports for lmgrd and ansyslmd
(echo >/dev/tcp//1055) &>/dev/null && echo "Open 1055" || echo "Close 1055"
(echo >/dev/tcp//1056) &>/dev/null && echo "Open 1056" || echo "Close 1056"
Hope this helps!
Geo
May 17, 2021 at 5:23 am
callum.walley
Subscriber.Thanks Geo,
We also had to fix the interconnect port to 1056 as it seems to be dynamic by default, but after that everything seemed to work.
- The topic ‘“Starting Licensing Client Proxy server” licence error’ is closed to new replies.
