3D Design
3D Design
SpaceClaimとMomentumをWin11でネームドライセンスで起動させたい
    • Masato Yamaguchi
      ①ネームドライセンスのSpaceclaimを使うために2020R2を入れてコマンドでアクティベートしようとするがエラーとなります。回避方法を教えてください。
      Microsoft Windows [Version 10.0.26100.6725]
      (c) Microsoft Corporation. All rights reserved. C:\Users\10073>cd C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64 C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64>ansysls_client.exe -ActivateLicenseEntitlement Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9
      2025/10/17 09:11:38    INFO                Starting local server.
      2025/10/17 09:11:38    INFO                C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysls_client.exe -nodaemon -log C:\Users\10073\AppData\Local\Temp\.ansys\ansysls_client.DCD0761.log
      2025/10/17 09:11:38    INFO                Started ANSYSLI server.
      2025/10/17 09:11:43    NEW_CONNECTION      Connected to local subscription handler: 59925@127.0.0.1
      2025/10/17 09:11:43    CLIENT_CONNECT        1/1/1/1   ::        6004
      2025/10/17 09:11:43    DENIED              Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9                                                             1/1/1/1   ::        6004                 Curl Error (35) SSL connect error - schannel: failed to receive handshake, SSL/TLS connection failed
      ERROR: Unable to activate entitlement with activation id 'Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9', error:
      Curl Error (35) SSL connect error - schannel: failed to receive handshake, SSL/TLS connection failed C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64> ②さらにAlgoryxMomentumをアドオンさせたいのですが バージョンは 何でしたら乗せられますでしょうか?
Viewing 0 reply threads
