3D Design
3D Design
SpaceClaim: wired operation outcome of split body
    • Dato
      Hi all,
      I'm using SpaceClaim to perform pre-processing on an assembly created from SolidWorks.
      It's a helical pipe. After I perform Split Body using surface as cutter,  weird new bodies has been created and a distorted surface has occurred unexpectedly.The pictures is as followed.
      It's really puzzling. It's my first time to encounter the problem in SpaceClaim. Anyone has some suggestions? It's highly appreciated!!
      Regards
      What version of Ansys are you using?
      • Dato
        I'm using 22R2. The problem is caused by the problematic geometry topology. I repaired and cleaned the geometry, then the operation and visualization problem is solved.
