3D Design
3D Design
SpaceClaim Cross Section View in Drawing Sheet not hiding geometry correctly
    • Jeremy Morgan
      I'm seeing some strange behaviour regarding Section views in a SpaceClaim Drawing sheet.
      A Section view is not hiding the parts of the geometry above the section plane. See 1st screenshot.
      If I rotate the view slightly, it's clearer (2nd screenshot). The part of the model shown by the red arrow should not be visible.
      I can't see any option that I need to set to fix this; and it isn't behaviour that SC used to exhibit.
      Any ideas?
    • Charudatta Bandgar
      Let me check this, Jeremy. I will get back to you shortly.
      Charudatta B
    • Jeremy Morgan
      @Charudatta
      Thanks for checking. I think the problem is on 2024 R2 version. I'm not seeing the problem in 2024 R1.
    • Jeremy Morgan
      @Charudatta
      Did you get anywhere with this?
