Solution for absent solver output file?
    • jamie.booth
      Hi all,
      I am performing some cohesive zone modeling for adhesive applications, and when solving I run into the following error - 'An error occurred inside the SOLVER module: general error'. To gain more information and debug I would typically review the solver output file, but no such file is being generated (see attached screenshot below). Any help on how to navigate this issue would be greatly appreciated. I would be happy to follow up with any additional information about the study set-up, if necessary.
      Jamie
    • ashish.khemka
      Please right click on Solution-> Open Solver Directory Files and there try to open the Solve.out file. Sometimes if the file size is too large then the output won't be displayed and you might need to open the file from the folder.
      Regards Ashish Khemka
    • jamie.booth
      Thanks for your response. I had actually already looked for the Solve.out file directly. It is simply not being created. See the attached screenshot.
      Regards Jamie
    • Hari Subramaniam
      Jamie
      When you are using Interface delamination, don't use a multibody part. Un-share the parts
      In workbench project page, Right click on geometry cell and select properties. Change the Analysis type from 3D to 2D
    • Nasrul Hassan
      Hi, i have the same problem to when trying to run static analysis in mechanical, "'An error occurred inside the SOLVER module: general error' and no solution file is create for me to check. Appreciate if you can assist solving this problem.
    • Ahmed Ahmed
      Hi also i have the same problem does anyone has any recommendations ?
    • Nanda
      Hello Ahmed,
      I can see another error regarding contact scope elements having no elements. Can you check your contacts and verify if they are properly defined.
      Nanda.
Viewing 6 reply threads
  • The topic ‘Solution for absent solver output file?’ is closed to new replies.
