Sharing topology between hexa- and tetra-mesh
    • EngSim
      Hi. I'd like to simulate a shell&tube heat exchanger. The tube side is made of 85 tubes, connected from both sides to two manifolds, as in picture (halfened geometry):
    • Karthik Remella
      Administrator
      Hello,nPlease try to use the 'Share Topology' option under the WorkBench Tab of SpaceClaim (Sharing -> Share)nTry this and let us know if you are seeing a conformal mesh.nOnce you obtain a mesh, please make sure that the overall quality is good.nThank you.nKarthikn
    • EngSim
      It works! Thank you so much!n
    • Karthik Remella
      Administrator
      Excellent! n
  • The topic ‘Sharing topology between hexa- and tetra-mesh’ is closed to new replies.
