October 29, 2023 at 7:03 amabdelhakim.kheriefnacereddineSubscriber
i'm using a 2D simulation in order to study the flow of a non-Newtonian fluide inside a pipe , i have changed the division of the cells , but it has not given comparable results yet . i do not know the reaso . Does anyone know how to divide geometry and messh in a good way ? knowing ( L=1.2) and (D=0.02) , i have tried several division as ( 50*750)Â , (50*500) , ( 100*1000) , (100*750) , who has an idea how to choose the division accurately ?
October 30, 2023 at 12:52 pmFedericoAnsys Employee
Are these dimensions (L*D) or (D*L)?
How far off are you from expected results? How do you know this is mesh related?
- The topic ‘search for a good 2D geometry for a pipe geometry’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
- RIBBON WINDOW DISAPPEARED
599
591
565
366
