March 6, 2024 at 6:01 pmArvind SinhaSubscriber
Is there a way to export ansys workbench file to apdl. I can save a *.mechdat file. I don't see any options in Tool command to export to mechanical apdl.
March 6, 2024 at 10:34 pm
- The topic ‘Saving ansys workbench file to ansys apdl (*.inp) for 2023 R1’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
591
544
524
366
