Electronics
Electronics
Running ANSYS HFSS on multiple nodes on SLURM based cluster
    • riswadkar1994
      Hi all,
      Could someone point me to some standardized instructions for running HFSS on multiple nodes on a SLURM based cluster? Currently we are limited by the RAM on a single node, but multi-core simulations(parametric sweeps) do work on a single node.
      I did find an interesting solution here(/forum/discussion/18341/running-hfss-on-a-slurm-based-machine-rsm-cannot-be-accessed), but cannot yet get my cluster admins to install ansoftrsmservice executable. Is there a way around installing this executable? I can see that ARC is pre-installed on the cluster, but running ARC node executable on every node before submitting the job might not be possible. If anyone has a standardized procedure for doing multi-node jobs on SLURM based clusters using ARC or anything else, I will be happy to hear that.
      I tried to submit a job on ansysedt on a cluster compute node (https://vis.tacc.utexas.edu/#) as follows:
      Tools->Job Management->Submit Job
      The hostnames of the assigned nodes is given by the NODELIST variable (squeue -u )
      Following is the preview of the job submission
      /home1/apps/ANSYS/AnsysEM20.1/Linux64/desktopjob -cmd dso -jobid RSM_14259 -machinelist list=c506-011:1:21:90%:1,c506-012:1:21:90%:1,c506-013:1:21:90%:1,c506-014:1:21:90%:1 -monitor -waitforlicense -useelectronicsppe -ng -batchoptions " -batchsolve 20210711_Single_Qubit1_a:Optimetrics:ParametricSetup1'work2/08252/ameya/stampede2/tmp/Cavity Qubit Start_parametric_2.aedt'
      I found the default port used by slurmd to listen for incoming requests from slurmctld is 6818 (https://slurm.schedmd.com/network.html) but I could not configure the port when submitting the job
      When I submit the job, I get a message that the job submission is successful and get redirected to Monitor Job - RSM which gives the following error message:
      Connecting to running job.
      Running LSDSO job 'RSM_5415'
      Location: /home1/apps/ANSYS/AnsysEM20.1/Linux64/desktopjob
      Batch Solve/Save: 'work2/08252/ameya/stampede2/tmp/Cavity Qubit Start_parametric_2.aedt
      Starting Batch Run: 04:11:30PM Thursday, August 12, 2021
      Temp directory: /tmp
      Error: (T=08/12/21 16:11:31): Failed to launch engine on machine 'c506-012' or obtain a compatible interface
      Error: (T=08/12/21 16:11:31): Failed to activate child job. Node 'c506-012' is removed from this job's available resources.
      Error: (T=08/12/21 16:11:31): Failed to launch engine on machine 'c506-013' or obtain a compatible interface
      Error: (T=08/12/21 16:11:31): Failed to activate child job. Node 'c506-013' is removed from this job's available resources.
      Error: (T=08/12/21 16:11:31): Failed to launch...
    • ANSYS_MMadore
      If you were to run version 2021R1 or 2021R2 there is direct integration with SLURM, please refer to Help Documentation. https://ansyshelp.ansys.com/Views/Secured/Electronics/v211/en/Subsystems/HFSS/HFSS.htm#HPC/IntegrationwithSLURMLinuxScheduler.htm%3FTocPath%3DHFSS%2520Help%7CHigh%2520Performance%2520Computing%7CHigh%2520Performance%2520Computing%2520(HPC)%2520Integration%7C_____8
      For running prior releases it does require a custom scheduler proxy and ansoftrsm.
      ARC is not an option.
    • riswadkar1994
      I tried using the scheduler proxy and running ansoftrsmservice on each node, I get the following error on all compute nodes on the cluster other than localhost
      Unable to locate or start COM engine on '192.168.217.68'
      I ran ansoftrsmservice on each node as follows:
      for NODE in $(cat nodefile_local_ip)
      do
      # start the RSM service
      ssh $NODE $WORKDIR/rsm/Linux64/ansoftrsmservice start
      # register engines with RSM (otherwise it'll complain that it can't find it)
      ssh $NODE /home1/apps/ANSYS/AnsysEM20.1/Linux64/RegisterEnginesWithRSM.pl add
      telnet $NODE 32958
      done
      The SSH and telnet works in connecting to the other compute nodes. SSH output tells me the following:
      Starting Ansoft Remote Simulation Manager: Done
      Registering product-specific engines with RSM...
      /home1/apps/ANSYS/AnsysEM20.1/Linux64/HFSSCOMENGINE: Done
      And the telnet output is
      Trying 192.168.217.49...
      Connected to 192.168.217.49.
      Following is my ansysedt command
      /home1/apps/ANSYS/2021R2/AnsysEM21.2/Linux64/ansysedt -regserver -autoextract -distributed -ng -machinelist list="${ABQHOSTS}" -UseElectronicsPPE -Logfile "9_21_21_2.log" -batchoptions $OptFile -batchsolve -monitor 20210711_Single_Qubit1_a:Optimetrics:ParametricSetup1 "/work2/08252//stampede2/tmp/Cavity_Qubit_Start_parametric_2.aedt"
      From reading the documentation, it looks like
      libdesktop.so calls a subroutine called "LaunchProcess" which the /schedulers/proxies.cfg file redirects to/schedulers/SLURM_LaunchProcess_linux.py which fails to start a process and schedulers/scripts/WinHPC/ansysem_messages.py produces the error message. I don't know where along this chain the error occurs.
      I even checked the network while running ansysedt:
      I find that the ansoftrsm does start listening on node 32958
      tcp00 0.0.0.0:329580.0.0.0:*LISTEN376438/ansoftrsmser
      I do find my SSH packets going through
      tcp00 192.168.217.49:33852192.168.217.51:22TIME_WAIT-
      And my telnet packets going through
      tcp00 192.168.217.49:57054192.168.217.50:32958FIN_WAIT2-
      I do see ansysedt and HFSSCOMENGINE connections on local ports, but nothing on the other local ip's that I provide for the other compute nodes
      tcp00 127.0.0.1:41246127.0.0.1:46590ESTABLISHED 427384/ansysedt.exe
      tcp00 127.0.0.1:45576127.0.0.1:39634ESTABLISHED 427818/HFSSCOMENGIN
      tcp1680 206.76.217.49:38506129.114.99.212:54845ESTABLISHED 427922/ansyscl
      Any help is much appreciated
    • J0sh8830
      Hi riswadkar1994, I hope you are doing well. I am having a similar issue trying to run a distributed solve on the cluster at my university. Have you had any luck with this issue yet?
      Best regards Josh
    • ANSYS_MMadore
    • riswadkar1994
      I did everything on that page (https://ansyshelp.ansys.com/Views/Secured/Electronics/v211/en/Subsystems/HFSS/HFSS.htm#HPC/IntegrationwithSLURMLinuxScheduler.htm%3FTocPath%3DHFSS%2520Help%7CHigh%2520Performance%2520Computing%7CHigh%2520Performance%2520Computing%2520(HPC)%2520Integration%7C_____8)
      until
      Using the generic scheduler with SLURM
      Everything in and after this section seems to be GUI based, but I don't have access to the GUI, I am submitting the job from a command line on the login node, after which SLURM schedules it with some compute nodes but I remain on the login node shell.
      Is there something that can be written in the batchoptions file to submit the SelectScheduler option from the command line? I do see that the error (Unable to locate or start COM engine on 'c506-124.stampede2.tacc.utexas.edu' :(12:03:38 PMSep 20, 2021)) comes from schedulers/scripts/WinHPC/ansysem_messages.py, where the slurm scheduler python files are located.
    • ANSYS_MMadore
      -- if submit using batch then need:
      export AppFolder=/opt/AnsysEM/AnsysEM21.2/Linux64
      export ANSYSEM_GENERIC_MPI_WRAPPER=${AppFolder}/schedulers/scripts/utils/slurm_srun_wrapper.sh
      export ANSYSEM_COMMON_PREFIX=${AppFolder}/common
      srun_cmd="srun --overcommit --export=ALL -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 --overlap "
      ${srun_cmd} ${AppFolder}/ansysedt -ng -monitor -waitforlicense useelectronicsppe=1 -distributed -machinelist numcores=XX -auto -batchoptions "" -batchsolve Project.aedt
    • ANSYS_MMadore
      Important,you must be running AEDT 2021R2 and SLURM 20.x for the following steps
      -- You would want to gather the following to confirm scheduler version and network info
      $ cat /etc/*release
      $ sinfo -V
      $ ifconfig
      Enabling tight integration change - this requires editing slurm_srun_wrapper.sh and setting batchoption 'RemoteSpawncommand'
      1.. edit the slurm_srun_wrapper.sh
      archive/copy .../AnsysEM21.2/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh to slurm_srun_wrapper.sh.ORIG
      edit .../AnsysEM21.2/Linux64/schedulers/scripts/utils/slurm_srun_wrapper.sh and insert the following at line 28: host=$(echo "${host}" | cut -d'.' -f1)
      ex:
      if [[ -n "$ANSYSEM_SLURM_JOB_ID" ]]
      then
      export SLURM_JOB_ID="${ANSYSEM_SLURM_JOB_ID}"
      echo "set SLURM_JOB_ID=${SLURM_JOB_ID}" >> "$DEBUG_FILE"
      fi
      => # tfs447753
      => host=$(echo "${host}" | cut -d'.' -f1)
      verStr=`scontrol --version`
      2.. After making the slurm_srun_wrapper.sh file change, run the following to set defaults to tight integration(will create/modify//AnsysEM21.2/Linux64/config/default.XML)
      as root or installation owner
      cd /opt/AnsysEM/AnsysEM21.2/Linux64
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Desktop/Settings/ProjectOptions/ProductImprovementOptStatus" -RegistryValue 0 -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS 3D Layout Design/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS-IE/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 2D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 3D/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Q3D Extractor/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Icepak/MPIVendor" -RegistryValue "Intel" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS 3D Layout Design/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "HFSS-IE/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 3D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Maxwell 2D/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Q3D Extractor/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Icepak/RemoteSpawnCommand" -RegistryValue "scheduler" -RegistryLevel install
      # ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey "Desktop/Settings/ProjectOptions/AnsysEMPreferredSubnetAddress" -RegistryValue "192.168.1.0/24" -RegistryLevel install
      4.. An example batch script:
      Create %HOME/anstest/job.sh with the following contents (correct highlighted):
      #!/bin/bash
      #SBATCH -N 3# allocate 3 nodes
      #SBATCH -n 12# 12 tasks total
      ##SBATCH --exclusive# no other jobs on the nodes while job is running
      #SBATCH -J AnsysEMTest# sensible name for the job
      #Set job folder, scratch folder, project, and design (Design is optional)
      JobFolder=$(pwd)
      ProjName=OptimTee-DiscreteSweep-FineMesh.aedt
      DsnName="TeeModel:Nominal"
      # Executable path and SLURM custom integration variables
      # setup environment and srun
      export ANSYSEM_TASKS_PER_NODE=${SLURM_TASKS_PER_NODE}
      # setup srun
      srun_cmd="srun --overcommit --export=ALL -n 1 --cpu-bind=none --mem-per-cpu=0 --overlap "
      # MPI timeout set to 30min default for cloud suggest lower to 120 or 240 seconds for onprem
      export MPI_TIMEOUT_SECONDS=120
      # System networking environment variables - HPC system dependent should not be user edits!
      # export ANSOFT_MPI_INTERCONNECT=ib
      # export ANSOFT_MPI_INTERCONNECT_VARIANT=ofed
      # Skip dependency check
      # export ANS_NODEPCHECK=1
      # Autocompute total cores from node allocation
      CoreCount=$((SLURM_JOB_NUM_NODES * SLURM_CPUS_ON_NODE))
      # Run Job
      ${srun_cmd} ${AppFolder}/ansysedt -ng -monitor -waitforlicense -useelectronicsppe=1 -distributed -auto -machinelist numcores=$CoreCount -batchoptions "" -batchsolve ${DsnName} ${JobFolder}/${ProjName}
      Then run it:
      $ dos2unix $HOME/anstest/job.sh
      $ chmod +x$HOME/anstest/job.sh
      $ sbatch $HOME/anstest/job.sh
      When complete, send resulting:
      $HOME/anstest/OptimTee-DiscreteSweep-FineMesh.aedt.batchinfo/*.log
    • riswadkar1994
      I am running slurm 18.08.5-2
    • riswadkar1994
      srun
      --overlap option is not recognized
    • ANSYS_MMadore
      Correct, please remove --overlap, that is only supported under version 20.
    • ANSYS_MMadore
      Please note, slurm 18 is not tested or supported.
    • zwyll
      Hi mmadore I have the root access to the machine that riswadkar1994 is running ANSYS HFSS on. And I have followed your step 1 and 2. Step 1 is pretty simple and has no problem. However, in step 2, I encounter two errors when running the command for HFSS-IE, which are
      staff.stampede2(575)# ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey ÔÇ£HFSS-IE/MPIVendorÔÇØ -RegistryValue ÔÇ£IntelÔÇØ -RegistryLevel install
      MPIVendor is not DSO option
      Available DSO options forare:
      HPCLicenseType
      registry key is not defined in this product
      error on to set registry value at
      and
      staff.stampede2(580)# ./UpdateRegistry -set -ProductName ElectronicsDesktop2021.2 -RegistryKey ÔÇ£HFSS-IE/RemoteSpawnCommandÔÇØ -RegistryValue ÔÇ£schedulerÔÇØ -RegistryLevel install
      RemoteSpawnCommand is not DSO option
      HPCLicenseType
      Other commands seem to be working well. Could you please let me know how to resolve these two issues?
      Thanks.
    • ANSYS_MMadore
      You can actually ignore the HFSS-IE entries, those are legacy and not required.
Viewing 13 reply threads
  • The topic ‘Running ANSYS HFSS on multiple nodes on SLURM based cluster’ is closed to new replies.
