November 27, 2023 at 5:49 pmgiacomoSubscriber
once a cerig connection has been created in ansys apdl between slave nodes and a master node, is it possible to constrain the same slave nodes with hinges?
Thank you
November 28, 2023 at 3:19 pmmrifeAnsys Employee
Hi Giacomo
Not if the degrees-of-freedom you mean to use in the hinge constraint have already been used in the CERIG. Â
- The topic ‘rules in ansys APDL’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
591
544
524
366
