February 11, 2020 at 6:05 pm
Nikhil26
SubscriberWhy it is not showing ICEM CFD as option along with ansys mesh in drop down menu??? (In the attached pic)
Also if I seperately open and import geometry file in ICEM CFD, it is showing previously meshed geometry!!
February 12, 2020 at 11:43 am
Forum ModeratorStaff are not permitted to open/download attachments.Â
March 18, 2021 at 4:35 pm
Dioser
SubscriberI have the exact same issue. I use Ansys 2019.R3 and I wanted to try the MultiZone meshing, for an external aerodynamics analysis on a wing, but when I go to Write ICEM CFD files, there is no interactive option, just yes and no. I really think that ICEM meshing would help out with my problem, but I have no idea how to enable it. I tried installing Ansys again, to see if there was an option to add ICEM with the normal Ansys installation, but there is not.nIf you could give us some guidance on this issue, it would be of immense help. Thank you!n
- The topic ‘Regarding ICEM CFD’ is closed to new replies.
