September 8, 2023 at 11:32 amJason HuangSubscriber
I received this error when reopening my previously saved case file in Fluent. Basically, I can get the result data with this case file when I set everything up the first time, but I receive this error every time when I reopen this case file. This case can be read and simulated on my friend's PC. Therefore, I believe my geometry and mesh are fine, and it might be my computer's problem. By the way, I can run other cases with my Fluent and I didn't use any user-defined function. Can someone help me out?Â
Thanks.
Here is the error message below:
Node 999999: Process 66448: Received signal SIGSEGV.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 17188 RUNNING AT ROG-PC
= EXIT STATUS: -1 (ffffffff)
= RANK 1 PID 28140 RUNNING AT ROG-PC
The fl process could not be started.
September 11, 2023 at 1:31 pmFedericoAnsys Employee
Hello,Â
you said this case can be run on your friend's PC, are they also able to read the .dat file?
Which version of Fluent are you using?
September 11, 2023 at 11:26 pmJason HuangSubscriber
Thanks for your reply. We are both using 2023R1. Because the data file is too large, I just shared the case file, but he can read and run the simulation.Â
September 12, 2023 at 1:54 pmFedericoAnsys Employee
Are you able to read the case file without the data? I'm trying to isolate the source of the problem.
September 12, 2023 at 11:28 pmJason HuangSubscriber
Nope, I cannot read my case file. It will give this error with or without the data file. But I can read other case files from my friend. It looks like my software cannot read the case files that were produced and saved from my local software. So, I think there are some reading problems with my software.Â
September 13, 2023 at 12:33 pmFedericoAnsys Employee
What version of Fluent are you using? And what is the output format of the case file? .cas/.cas.h5/.cas/gz?
September 13, 2023 at 12:38 pmJason HuangSubscriber
I'm using Fluent 2023R1 and Workbench 2023R1. The output file is cas.h5.
September 13, 2023 at 12:46 pmFedericoAnsys Employee
From a clean state, meaning after running the case from your machine, can you try to write the case and solution data in uncompressed format .cas/.dat (just change the file type when you write the files, File > Write > Case & Data).
Then see if you can read these new files.
September 13, 2023 at 1:23 pmJason HuangSubscriber
I just set everything up and wrote my case in .cas format. But I still got that error.
- The topic ‘Received signal SIGSEGV’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
- RIBBON WINDOW DISAPPEARED
1421
599
591
565
366
