RBE2 equivalent in Ansys Mechanical
    • colin.souza
      Hello all,
      I want to run static and modal analyses on a fan impeller. Until now we have performed our analysis in PATRAN/NASTRAN. We model the impeller as an assembly of surfaces and the shaft as a 1D line. The mesh ends up as shells and 1D beam elements. To connect the 2D shell impeller mesh to the 1D beam shaft elements we used the RBE2 multi-point constraint. This rigidly linked the shell nodes degrees of freedom to the beam node DOFs.
      I am trying to replicate this in Ansys Mechanical and am hitting a bit of a wall. Ansys seems to have lots of tools for applying remote boundary conditions of different sorts, but I am connecting geometry. Ansys also has 'contact' tools but they don't seem to apply to my need to connect to a single node on a beam element.
      The closest I can get to is the Remote Point, but I haven't figured out how to connect the master 'point' to my beam node yet.
      Any ideas on what tools to use, or even what general area to search for would be much appreciated.
      Colin
      Shell / beam model of fan impeller on shaft
    • Erik Kostson
      Hi
      Split the beam at the location where the RBE2 spider will be then:
      Using a connection/joint of fixed type ( a fixed joint):
      Fixed – Surf 2 To Line Body – Scoped
      Between shell hole edge and vertex on the beam (can not be scoped to a node, but where there is vertex there is a node, hence why we split the beam there).
      This video shows this in detail.
      https://www.youtube.com/watch?v=tQykfXMuQp4
