Ansys Products
Ansys Products
PyFluent unable to connect to running Fluent server
    • fsae.unitn
      I already have a Fluent HPC server running on my cluster. I would like to connect and send commands to it using PyFluent, but when I try to do so, I get the following error:
      RuntimeError: failed to connect to all addresses; last error: UNIMPLEMENTED: ipv4:127.0.0.1:50000: Trying to connect an http1.x server (HTTP status 404)
      For reference, this is the code. 50000 is the port the webserver is running on:
      fluent = pyfluent.connect_to_fluent(
          ip="127.0.0.1",
          port=50000,
          password=""
      The WebUI works and is accessible from a web browser. We've tried using both a hostname, the local IPv4 adress and the loopback address, with the same results.
    • Ashish Khemka
      Please post this query on our developer forum: Home - Community Forum
      Thanks and Regards,
      Ashish Khemka
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
